Learn MoreWe would like to give a big thank you to Dr. Lekan Popoola, Senior Research Associate at the University of Cambridge for assisting our science team with the following research. Also, a big thank you to our internal science team, led by Dr. Anika Krause, for their continued scientific rigour throughout this research process.
Within the next few months, we at AirGradient are preparing to release a new outdoor air quality monitor, the AirGradient Open Air Max. This monitor is intended for applications requiring reliable, standalone outdoor measurements, such as detailed urban air quality mapping or research projects. It builds upon our previous Open Air design by incorporating several new features and sensors that make it better suited to professional requirements.
Like our Open Air monitor, the Open Air Max will measure particulate matter, CO2, TVOCs, temperature, and relative humidity (RH). Adding Nitrogen Dioxide (NO2) and Ozone (O3) sensors was also a direct response to common requests from customers, who needed data on traffic-related emissions and other key outdoor pollutants. Accurately measuring these gases is important for assessing outdoor air quality, particularly in urban areas. Crucially, we aimed to integrate these professional-grade sensors while keeping the Open Air Max relatively affordable.
However, integrating new sensors, especially for reactive gases like NO2 and O3, requires careful consideration. The market includes various sensors with different technologies, performance characteristics, and price points. Selecting appropriate sensors for the Open Air Max involved extensive research and testing to evaluate their suitability to measure reliably in real-world conditions. This is critical because unlike controlled laboratory environments – which often use fixed temperatures, humidity levels, and only the target gas – real-world ambient conditions are complex. Therefore, rigorous testing against reference instruments in these dynamic outdoor environments was essential. While this required significant time and effort, we wanted to ensure the sensors we and our customers rely on have acceptable accuracy and reliability.
"Drawing on my years of research in atmospheric science and air quality, it's clear that selecting a low-cost sensor (LCS) for monitoring air pollutants in ambient environments demands thoughtful consideration. The right choice often depends on the intended application—be it source identification, citizen science, community engagement, or scientific research.
While original equipment manufacturer (OEM) sensors may perform adequately under controlled test conditions, their integration into LCS platforms for ambient air quality monitoring can lead to suboptimal results. This is often due to environmental influences and, at times, substandard device configuration. Therefore, sensor selection should go beyond manufacturer specifications and take into account real-world performance.
To support the LCS community, it is essential to share insights into how these sensors perform in practical settings. This blog highlights our evaluation of LCS sensors in measuring two key air pollutants: nitrogen dioxide (NO2) and ozone (O3)."
As we’ve now concluded our research and decided on the sensors we will be using, we wanted to share our results with you. We wanted to do this not only to show just how much research goes into each sensor decision we make but also to discuss transparently what led to our final decision. If you’re interested in our evaluation process and the data from our research, please read on!
| Manufacturer & Model | Unit price | LOD | resolution | drift | O3 cross- sensitivity | lifetime | Temp & RH range |
| Ec-sense TB600B-NO2-2 | $$ | 5 ppb | < 5 ppb | < 5% / year | 0.1ppm @ 1 ppm | > 3 year | -20°C - 70°; 0 - 100% |
| Alphasense NO2-A43F | $$ | ? | 15 ppb | 0-20 ppb / year | O3 filter → cross sensitivity close to 0 | 2 years | -30 - 40°C, 15-85% |
| Winsen ZE12A-NO2 | $$$ | ? | ≤ 10ppb / 1 ug/m3 | 10% | No O3 filtering system | 2 years | -20~50℃, 15-90% |
| Amphenol SGX Sensortech PS1-NO2-2 | $ | ? | < 5 ppb | < 1 %/ month | 0.1ppm @ 0.25 ppm | > 3 years | -40°C to +55°C, 15-95% |
| SPEC NO2 - 110-508 | $ | 30 ppb | 10 ppb | ? | Measures O3+NO2 | 10 years | -30 to 55°C, 10 to 95% |
Our initial research surveyed several commercially available electrochemical sensors for NO2 detection. Finding a reliable and affordable sensor suitable for widespread deployment required balancing performance claims, technical specifications, cost, and practical considerations like manufacturer support. Here's a brief overview of the candidates we initially considered and why we decided either to progress further with assessing each sensor or why we excluded them from the running:
This initial review highlighted two leading contenders that seemed most promising for deeper evaluation based on their specifications, market reputation, and potential suitability for our requirements:
Based on this information, we decided the next step was to carry out a side-by-side comparison under real-world conditions. Our detailed testing phase, therefore, focused primarily on evaluating the performance of EC Sense versus Alphasense sensors for both NO2 and the corresponding O3 sensors from each manufacturer. The rest of this article details the setup and results of that comparative deployment.
To make a final (and informed) decision, theoretical specifications and manufacturer claims are not enough. We needed to see how these sensors performed in real-world, ambient conditions. We conducted a co-location study to achieve this, deploying the candidate sensors directly alongside high-grade reference instruments.
Deploying pairs of sensors helps assess unit-to-unit variability and ensures conclusions aren't based on a single potentially anomalous sensor. However, we tested two of each sensor.
With this setup, we could directly compare the output of the Alphasense and EC Sense sensors against trusted reference measurements under identical environmental conditions.
Before delving into hourly performance metrics, examining the raw, high-resolution (5-minute) data provides valuable initial insights into sensor behavior. During this phase, two key characteristics immediately stood out: signal noise and data truncation.
Please note that for the later comparisons in this article, we opted to use the better-performing sensor from each pair from this initial testing.
Signal-to-noise Ratio: When comparing the 5-minute readings, a noticeable difference in signal stability emerged. The EC Sense NO2 sensors exhibited considerably more noise in their output compared to the Alphasense sensors. While all electrochemical sensors have some inherent signal noise, the fluctuations in the 5-minute EC Sense NO2 readings were significant, on the order of 5-8 ppb peak-to-peak (as observed in the second set of graphs above).
In contrast, the raw voltage signals from the Alphasense sensors (as seen in the first set of graphs) appeared smoother relative to the reference trends. While hourly averaging smooths out much of this noise, high raw signal noise can sometimes indicate underlying instability, thereby limiting the sensor's ability to detect small, rapid changes in concentration.
Data Truncation in EC Sense Ozone: A more critical observation arose from the EC Sense O3 sensors' 5-minute data. We consistently found that the sensors did not report any values below a threshold of approximately 9-10 ppb (as clearly shown in the second set of graphs above). The data output was effectively "flat-lining" at this level, even when the reference instrument simultaneously measured O3 concentrations well below this value – levels which are still environmentally relevant.
These initial observations from the 5-minute data already flagged important differences. The higher noise in EC Sense signals suggested potential challenges in resolving finer concentration changes, while the O3 data truncation represented a major limitation in capturing the full range of ambient ozone levels.
Moving to hourly averaged data allows for a clearer comparison of how well the sensors track ambient concentration trends against the reference instruments (since most reference instruments only report on an hourly basis). In this step, we evaluated the sensors using generic scaling factors derived from the deployment data but without applying specific corrections for cross-interferences between NO2 and O3. This involved a simple comparison of the peak-to-trough ratios of the plots shown above relative to the reference signals for each species. This represents a baseline or "out-of-the-box" performance level.
Alphasense: The Alphasense NO2 sensors performed well right from the start. As shown in the time series and scatter plots above, the hourly Alphasense readings tracked the reference NO2 concentrations closely. We calculated strong Pearson’s correlation coefficients (r) of around 0.88-0.89, indicating a good linear relationship.
The Root Mean Square Error (RMSE), a measure of the average prediction error, was also reasonably low at approximately 3-4 ppb. This good initial performance is likely aided significantly by the built-in ozone filter in the Alphasense model, which is designed to minimize interference from ozone, a known cross-interferent for electrochemical NO2 sensors.
EC Sense: The results for the EC Sense NO2 sensors, without any correction, were starkly different. The time series showed little resemblance to the reference NO2 trends, and the scatter plots revealed virtually no correlation (Pearson's r ≈ 0), as seen above. The RMSE was consequently very high, around 14-19 ppb. This demonstrates that the EC Sense NO2 sensor, despite its name, does not selectively measure NO2 out-of-the-box. Its signal appears heavily influenced by other pollutants, strongly suggesting it behaves primarily as an Ox (NO2 + O3) sensor. The inability to distinguish NO2 from O3 renders its uncorrected output unusable for determining actual NO2 levels. More importantly, the comparative statistics are hugely negatively impacted by the truncations of the EC Sense signal below 10 ppb. A significant proportion of the true NO2 values from the reference falls below the redaction value; this limits the data available to establish a reliable relationship with the reference.
Alphasense: The Alphasense O3 sensors also showed generally good agreement with the reference instrument on an hourly basis. Correlations were strong (r ≈ 0.85-0.87), and the RMSE was acceptable at around 5-6 ppb. While some deviations were visible, particularly at lower concentrations, the overall tracking was satisfactory for an uncorrected sensor.
EC Sense: The performance of the EC Sense O3 sensors was mixed and generally lagged behind Alphasense. While one sensor showed a reasonable correlation (r ≈ 0.85), the other was weaker (r ≈ 0.66), and RMSE values were higher (≈ 7-13 ppb). More importantly, the impact of the data truncation below ~10 ppb, first observed in the 5-minute data, remained clearly visible in the hourly averages. Both the time series and scatter plots show a distinct lack of data points below this threshold, confirming the sensor's inability to capture lower O3 concentrations. This truncation significantly limits the sensor's usefulness, as it misses a relevant part of the typical ambient O3 range.
The out-of-the-box comparison revealed significant performance differences. Alphasense NO2 sensors provided immediately useful NO2 data, while EC Sense NO2 sensors do not output any useful raw measurements due to strong O3 interference.
For O3, Alphasense showed better baseline performance, while EC Sense was critically hampered by its low-concentration data truncation. This led us to investigate the potential improvements offered by cross-sensitivity corrections.
Electrochemical sensors are often susceptible to interference from gases other than their target analyte. For NO2 and O3 sensors, O3 can interfere with NO2 measurements, and NO2 can interfere with O3 measurements. Applying correction algorithms can potentially improve accuracy, but the effectiveness and practicality depend on the sensor's behavior and the availability of reliable data for the interfering gas.
Correcting EC Sense NO2 for Ozone Interference
Given the EC Sense NO2 sensor’s behavior observed in the out-of-the-box results, applying an ozone correction was essential to even attempt extracting a meaningful NO2 signal. We investigated this by subtracting a 100%contribution of ozone from the sensor's signal.
Initially, we attempted to use the data from the co-located EC Sense O3 sensor for this correction. However, as established earlier, the EC Sense O3 data was severely compromised by the truncation below ~10 ppb. This missing data made it unreliable for accurately correcting the NO2 sensor, especially during periods of low ozone.
Therefore, to assess the potential best-case performance of the EC Sense NO2 sensor, we applied a correction using the reference O3 instrument data. The results (shown below) were dramatic. The correlation with reference NO2 improved significantly (Pearson's r > 0.8), and the RMSE dropped considerably (to around 4.5 ppb).
This confirms that the EC Sense sensor can provide a reasonable estimate of NO2 for cases where the NO2 reading is well above the truncation value, but only when its strong ozone interference is actively compensated for using accurate, concurrent ozone measurements. The critical limitation here is the reliance on external, reference-grade O3 data to achieve this. In a standalone deployment of the Open Air Max, such reference data is not available. The sensor's own compromised O3 data was insufficient, making independent, accurate NO2 measurement with this sensor problematic.
Correcting Alphasense O3 for NO2 Interference:
Ozone sensors can also exhibit some cross-sensitivity to NO2. We evaluated the potential to improve the Alphasense O3 readings by correcting for this interference. We could perform this correction using data from the co-located Alphasense NO2 sensor (the A43F model), which already provides a good NO2 estimate.
Applying this correction yielded a noticeable improvement in the Alphasense O3 sensor's performance. The correlation with the reference O3 increased further (Pearson's r > 0.93), and the RMSE decreased to approximately 3-4 ppb, indicating enhanced accuracy across the measured range.
The key advantage here is independence. This correction utilizes data readily available from the paired Alphasense sensor (NO2 and O3) within the same monitoring device. It doesn't rely on external reference instruments, making it a practical method for improving accuracy in real-world, standalone deployments like the Open Air Max.
This analysis highlighted a vast difference in practicality. While the EC Sense NO2 sensor required correction using secondary and often unobtainable (in situ) reference O3 data to be useful, the Alphasense O3 sensor benefited from correction using readily available data from its paired Alphasense NO2 sensor. This capability for independent, self-consistent correction significantly favors the Alphasense sensor pair for standalone monitoring applications.
After analyzing the out-of-the-box performance and the impact of corrections, we conducted a final head-to-head comparison based on the best achievable results for each sensor type under practical conditions.
NO2 Performance Summary
We compared the Alphasense NO2 sensor (using its internal filter, no external correction needed) against the EC Sense NO2 sensor after it was corrected using reference O3 data (its best-case, though impractical, scenario).
While the corrected EC Sense performance approaches that of Alphasense, the crucial difference is independence. Alphasense delivers reliable NO2 data on its own, whereas EC Sense requires external data unavailable in typical deployments, confirming its fundamental Ox behavior in this configuration.
O3 Performance Summary:
We compared the Alphasense O3 sensor (corrected using its paired Alphasense NO2 data) against the EC Sense O3 sensor (using its standard scaling/correction).
The comparison for O3 is clear. The Alphasense sensor, especially when self-corrected, provides significantly more accurate and complete data across the relevant ambient concentration range. The EC Sense O3 sensor's truncation issue severely limits its utility for ambient monitoring.
Based on the comprehensive data collected during the Cambridge co-location study (December 2024 - February 2025), the Alphasense sensors demonstrated superior overall performance and practicality for integration into the AirGradient Open Air Max:
Therefore, based on this rigorous evaluation, we selected the Alphasense NO2-A43F and Alphasense OX-A431 sensors for integration into the AirGradient Open Air Max.
We believe in constructive feedback and transparency. While the EC Sense sensors showed some potential, particularly regarding their new technology, which might offer benefits in longevity or stability (though not verifiable in our winter deployment), several aspects hindered their performance in our ambient air quality monitoring tests. We offer the following suggestions for consideration:
We appreciate the innovation EC Sense is bringing to the sensor market and hope these feedback contributes to the ongoing development and refinement of their products for demanding applications like ambient air quality monitoring.
