The AirGradient DIY Outdoor Pilot Program
These instructions are for our small beta tester group and contains a special firmware for testing purposes. This firmware only works for people in this pilot program. If you are interested to join the pilot, please contact us.
If you just want to build the regular open hardware version of this outdoor monitor, follow these instructions. You can also pre-order this outdoor monitor as a kit in our Online Store.
Flashing of Pilot Firmware Through The Browser
DIY Outdoor Pilot Firmware
Connecting to WiFi Testing And Putting It Into The Enclosure
Now you can power on the device. You need to connect it to the Wi-Fi. To do this open you Wi-Fi settings on the phone and look for a hot spot called “AirGradient______”. Then connect to it and enter your Wi-Fi network credentials. It will then connect to Wi-Fi and start displaying and sending the air quality data.
Important: Please write down the serial number of the monitor. It is the code you see on the SSID after “AirGradient”. You need this code to add the monitor to the dashboard and for us to white list the monitor. In case you have any issue, please contact us.
If everything works, you can put the two PMS sensors and the PCB into the enclosure and close the enclosure with four screws. You need an M6 torx screwdriver.
3D Enclosure
You can download STL 3D printer files to print an enclosure that exactly fits the PCB. The 3D enclosure consists of three parts: two parts for the bottom and a bigger top part.
Download Enclosure STL Files
3D printable Outdoor enclosure
