Setup Opening Hours and Closed Days / Holidays
In the AirGradient admin section you can setup opening hours and closed days. You can reach the Place Administration with the hamburger menu or via https://app.airgradient.com/settings/place . Please note that this administration menu is ONLY available for administrators.
Opening Hours
The opening times of the organisation should be set up here, e.g. Mon-Fri 08:00 - 18:00. If you want a 24/7 monitoring please define Mon-Fri 00:00-24:00.
It is important to set this up as reports are only taking values into consideration that happened during opening hours. Also the charts on the dashboard shows times outside opening hours in grey or lighter colored colors.
Here you can also set up holiday periods to avoid reports being sent during these times.
It is important to set this up as reports are only taking values into consideration that happened during open days.
