The AirGradient DIY Air Quality Sensor (Pro Presoldered-Version, PCB Version < 3.7)
These build instructions cover the pre-soldered version of the AirGradient Pro monitor kit for PCB version 3.6 and lower. If you have a different version please find your correct build instructions in this overview. The version number is printed on the PCB.
| Skill | Description |
| Screwdrivers | You need Philips and hex (M6) Screwdrivers to close the enclosure. |
| AirGradient Pro PCB | with OLED Display, connectors and pin sockets |
| D1 Mini v4 USB-C | with pre-soldered pins |
| SHT31 Temperature and Humidity Sensor Module | with pre-soldered pins |
| Screws | The longest screws are for the enclosure. The screws with the washer head are for the PCB and the remaining screws for the PMS sensor. |
Assembly
The assembly of the pre-soldered parts is very simple, just make sure you mount the components in the correct direction. The labels on the components should match the labels on the PCB.
D1 Mini
Put the D1 microcontroller onto the pin sockets labelled "Microcontroller". Make sure that the orientation is correct and all pins slide into the sockets.
SHT31 Module (Temperature and Humidity)
Put the SHT31 Module onto the pin sockets labelled "SHT". Make sure that the orientation is correct and all pins slide into the sockets.
PMS5003 (PMS Sensor)
The PMS Sensor is connected with the enclosed cable to the PCBs JST connector.
The pre-soldered version of the kit comes with the microcontroller D1 already flashed so that you can immediately use it. However, you might want to flash it again or change the code (e.g. to connect it to a different server). Also, the pre-soldered kit comes flashed by default with Celcius for the temperature unit and if you would like to use Fahrenheit you would need to reflash with below.
Note that you cannot flash through the USB-C port on the PCB as this one is only for power. For flashing always use the USB port on the D1 Mini itself.
| For Standard PRO Presoldered Kit | |
| With temperature in Celcius and Display top-left |
| With temperature in Fahrenheit and Display top-left |
| With Code for Optional SGP4x AirGradient TVOC Module | |
Manual Flashing with the Arduino Software
| 2 | Once it is installed, go to File, Example, AirGradient and select the PM OLED code |
The AirGradient DIY sensor's hardware and software is open source and licensed under the MIT license. So feel free to use it any way you like. We would be happy to hear from you and also appreciate any link back to our page.
