How to Find the Firmware Version of Your AirGradient Monitor
There are several ways to check the firmware version of your AirGradient monitor.
Option 1: From the Dashboard
- Open the AirGradient Dashboard
- Go to Hardware
- All registered monitors are listed there
- The firmware version is shown for each monitor
You can also find the firmware version this way:
- Go to Dashboard
- Find the monitor you want to check
- Click the Admin (gear) icon
- Look under Monitor Information
You’ll see the current firmware version there.
Option 2: Using the Local API (Advanced)
If your monitor is connected to your local network, you can also check the firmware version through the monitor’s built-in local API.
Use this address in your browser:
http://airgradient_<YOUR_SERIAL_NUMBER>.local/measures/current
Replace <YOUR_SERIAL_NUMBER> with your own monitor’s serial number.
Example:
http://airgradient_ecda3b1eaaaf.local/measures/current
You’ll receive a JSON response like this:
"pm01": 69.67,
"pm02": 112.83,
"pm10": 116.5,
"pm01Standard": 104.83,
"pm02Standard": 170,
"pm10Standard": 175.33,
"pm003Count": 5643,
"pm005Count": 5151.17,
"pm01Count": 1112,
"pm02Count": 101.33,
"pm50Count": 4.33,
"pm10Count": 1.67,
"pm02Compensated": 90.18,
"atmp": 22.28,
"atmpCompensated": 22.28,
"rhum": 49.39,
"rhumCompensated": 49.39,
"rco2": 852,
"tvocIndex": 226,
"tvocRaw": 32009.5,
"noxIndex": 2,
"noxRaw": 15909.92,
"boot": 3177,
"bootCount": 3177,
"wifi": -38,
"ledMode": "co2",
"serialno": "",
"firmware": "3.6.2",
"model": "I-9PSL"
The value shown under firmware is your installed version.
