How do I replace a sensor module?
AirGradient monitor are repairable and modular. Sensor modules can be replaced when needed. See below for video instructions for the monitor and the module you want to replace.
Before opening the monitor
  • Disconnect the monitor from its power source.
  • Work on a clean, dry surface.
  • Handle sensor cables and connectors gently.
  • Do not open the monitor while it is powered or connected to a power adapter.
AirGradient ONE
PM module
TVOC/NOx module
CO2 module
Temperature / Humidity module
AirGradient Open Air
PM module
TVOC/NOx module
CO2 module
After replacing a module
Reconnect the monitor to power and confirm that the relevant sensor is reporting data. If the sensor does not appear or the readings remain invalid, contact support.
