Connect AirGradient ONE to WiFi with the QR code
Connect AirGradient ONE to Wi-Fi by scanning the device QR code with iOS or Android.
  1. Power on the monitor
  2. Scan the QR code called "Add to WiFi" on the back of the monitor
  5. Wait for the WiFi Manager screen popping up. In case the WiFi manager does not appear, open 192.168.4.1 on your browser
  6. Press "Scan for Network"
  7. Select the WiFi network or enter it manually in case it is hidden
  9. Successful connection is indicated with green LEDs.
