Connect AirGradient Open Air to WiFi with the QR code
Connect AirGradient Open Air to Wi-Fi by scanning the setup QR code on the device.
  1. Power on the monitor
  2. Scan the QR code called "Add to WiFi" on the back of the monitor
  5. Wait for the WiFi Manager screen popping up. In case the WiFi manager does not appear, open 192.168.4.1 on your browser
  6. Press "Scan for Network"
  7. Select the WiFi network or enter it manually in case it is hidden. Please note that the monitor only supports 2.4GHz networks
  9. Once the monitor has found an active internet connection, its LED will blink 3 times slowly
