Connect AirGradient ONE to WiFi without QR code
Manual Wi-Fi setup for AirGradient ONE by joining the airgradient hotspot and entering network credentials.
  1. Power on the monitor
  2. Find a WiFi hotspot called "airgradient-xxxxx" and connect to it. Use the password "cleanair"
  5. Wait for the WiFi Manager screen appearing. In case the WiFi manager does not appear, open 192.168.4.1 on your browser
  6. Press "Scan for Network"
  7. Select the WiFi network or enter it manually in case it is hidden
  9. Successful connection is indicated with green LEDs.
