Connect AirGradient Open Air to WiFi without QR code
  1. Connect the monitor to the power supply
  2. Find a WiFi hotspot called "airgradient-xxxxx" and connect to it. If a password is prompted, use the password "cleanair"
  5. Wait for the WiFi Manager screen appearing. In case the WiFi manager does not appear, open 192.168.4.1 on your browser
  6. Press "Scan for Network"
  7. Select the WiFi network or enter it manually in case it is hidden. Please note that the monitor only supports 2.4GHz networks
  9. Once the monitor has found an active internet connection, its LED will blink 3 times slowly
