The AirGradient DIY Air Quality Sensor (Basic Version PCB Version < 3.0)
- Introduction and Video
- Skills and Equipment
- Components
- Schematics
- PCBs
- Software
- Soldering the Components
- 3D Enclosure
- Dashboard
- License
Please note that this is a legacy instruction for people having the DIY BASIC PCB labelled with "PCB v2". The version number is written on your PCB. If you have a different version please find your correct build instructions in this overview.
As part of the Open AirGradient movement, this instruction teaches you how to build a compact and powerful air quality monitor with AirGradient.
You will need some basic soldering skills, and experience with microcontrollers is a plus. However, even if you are a beginner, you won’t need to worry because we made the instructions really easy!
If you want to build a monitor with a larger display, a better enclosure and more extensibility, check out the DIY Pro instructions.
We also offer the DIY Pro kit as a pre-soldered version for a very easy assembly that can literally be built in 5-10 minutes. More Information about the pre-soldered kit.
Jeff featured our DIY Basic kit on his YouTube channel and created a very nice video on how to assemble the monitor.
Skills and Equipment required
| Skill | Explanation |
| Basic soldering skills | The D1 Mini microprocessor and some of the components such as the OLED display need to have the pins soldered onto them. It is not very difficult and you can learn it easily. See this useful tutorial. |
| Soldering iron & Solder | To solder the component pins and cables. |
| Computer | A Linux, Mac, or Windows computer with the Arduino IDE installed to flash the software onto the D1 Mini. |
| Micro-USB Data Cable | To connect the D1 Mini to the computer for flashing and later for electricity. IMPORTANT: Many Micro-USB cables only provide charging but do not allow the data transfer for flashing. Please make sure you have a Micro-USB DATA cable. |
| Wemos D1 Mini | USD 2 - 4 |
| Wemos OLED display | USD 2 - 3 |
| SHT30 or SHT31 Temperature and Humidity Sensor Module | USD 3 - 5 |
You can also purchase the kit from our Online Store Online Store. We ship world-wide.
In case you want to make your own PCBs you can use the Gerber files or open the PCB schematic in the Easyeda editor and order PCBs from there.
Note that you cannot flash through the USB-C port on the PCB as this one is only for power. For flashing always use the USB port on the D1 Mini.
| Features | |
| With temperature in Celcius | Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP! |
| With temperature in Fahrenheit | Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP! |
| 2 | Once it is installed, go to File, Example, AirGradient and select the PM OLED code |
Put the long female and male pins through the D1 Mini. Make sure that the female parts are on top of the D1 Mini as shown in this picture:
D1 Mini Soldering Onto PCB
The next step is to solder the D1 Mini onto the PCB. Please make sure you solder it the correct way. The Micro-USB port needs to face outwards. You can also compare the pin labels on the PCB with the ones on the D1 Mini. You can either solder the D1 Mini directly onto the PCB or use the pin headers as a socket. If you solder it directly, please leave a small gap between the PCB and the D1 Mini to make sure the plug is accessible.
Soldering The SHT30/31 Module (Temperature and Humidity)
To solder the small pins onto the SHT30/31 module, you can again use a breadboard to fix it in place.
Then put the SHT30/31 module through the corresponding holes on the PCB and solder it onto the board. You only need to solder the four pins. No need to do anything with the two pins on the top of the sensor.
To solder the small pins onto the S8 module, you can again use a breadboard to fix it in place.
Please make sure that the pins face downwards as can be seen on this image.
Then solder the CO2 sensor onto the PCB. It is important that the bottom side of the CO2 has enough air flow. So make sure the gap is sufficient. It might be a good idea to put it on a female pin socket but you can also solder it directly. You can use the pin that came with the D1 Mini but you need to cut them down to the required length.
Normally the PMS5003 comes with a cable. As we will solder one end of the cable directly onto the PCB, you can cut the connector off one end of the cable. Then prepare the following four wires as per this image. Please make sure you cut the correct wires.
After you have soldered the cable to the PCB, connect the PMS5003 with the other end of the cable. Then screw the PMS5003 onto the PCB or use double sided tape to fix it in place.
Done & Enjoy
3D Enclosure And Mount
comment: <> (
AirGradient offers a sophisticated, powerful and responsive Air Quality Monitoring Solution for Schools. You can connect these DIY monitors to the AirGradient platform, and integrate with many existing brands or use our professional AirGradient ONE monitor.
The AirGradient DIY sensor's hardware and software is Open Source and licensed under the MIT license. So feel free to use it any way you like! However we would be happy to hear from you and also appreciate any link back to our page.
