The AirGradient DIY Air Quality Sensor (Pro Presoldered-Version, PCB Version 4.2)
Pre-soldered version of the AirGradient DIY Pro air quality monitor. Replaced by newer instructions.
These build instructions cover the pre-soldered version of the AirGradient Pro monitor kit for PCB version 4.2. If you have a different version please find your correct build instructions in this overview. The version number is printed on the PCB.
Video Tutorial
Skill Description
Screwdriver You need a Torx (T6) screwdriver which is included in the kit.
Component Approx. Price
AirGradient Pro PCB with OLED Display, connectors and pin sockets
D1 Mini v4 USB-C with pre-soldered pins
Plantower PMS5003 PM Sensor with cable
Senseair S8 CO2 Sensor with pre-soldered pins
SHT31 / SHT40 Temperature and Humidity Sensor Module with pre-soldered pins
USB-C Cable 90-degree head
Screws for Enclosure M1.8x10 (Torx T6)
Screws for PCB M2*4.5 (Torx T6)
Screws for PM Sensor M2*4.5 (Torx t6). Same screws as for PCB.
The schematics
The schematics
Assembly
The assembly of the pre-soldered parts is very simple, just make sure you mount the components in the correct direction. The labels on the components should match the labels on the PCB. The PCB might come in green or black color but are functionally identical.
Picture of fully assembled board
D1 Mini
Put the D1 microcontroller onto the pin sockets labelled "Microcontroller". Make sure that the orientation is correct and all pins slide into the sockets. Ensure that the USB port of the D1 faces inwards and the antenna outwards.
D1 Mini Placement
D1 Mini Placement
SHT31 / SHT40 Module (Temperature and Humidity)
The kit comes either with an SHT31 or an SHT40 temperature / humidity module. Please check below how to install it.
If you have the SHT31 Module, then put it on the pin sockets labelled "SHT". Make sure that the orientation is correct and all pins slide into the sockets as per picture below.
SHT31 Module
SHT31 Module
If you have the SHT40 Module with the AirGradient icon on it and the 90 degree pins, then you need to put it into the pin headers forward facing as per the picture below.
SHT40 Module
SHT40 Module
SHT Module
SHT Module
The CO2 sensor uses a 7 day automatic baseline calibration and thus might need some time to become accurate.
PMS5003 (PMS Sensor)
The PMS Sensor is connected with the enclosed cable to the PCBs JST connector. Please note that in v4.2 of the PCB, we use a shorter cross-over cable. This means that the longer cable in the previous kits will not work as the longer cable is not of cross-over type. You need to press the cables into the PM sensor and connector tightly. Please ensure that the cable is fully plugged in on both ends.
PMS Location
PMS Location
PMS JST Connector
PMS JST Connector
Screws for PMS Sensor
SGP41 AirGradient TVOC / NOx Module
The newer kits now contain the AirGradient TVOC / NOx module by default. Please mount that module on below slot.
Slot for AirGradient TVOC / NOx Module
Please make sure you mount the module in the correct orientation. The sensor needs to face outwards.
Screws for PCB
Screws for PCB
Location for PCB screws
Screws for enclosure
Location for enclosure screws
Soap helps getting the screws into the enclosure in case you use the mini screwdriver
The pre-soldered kits come with the default AirGradient software already pre-installed but if you want to reflash it, you can follow the instructions below.
You can either manually flash the code through the Arduino software or use the more simple buttons below. If you want to use the Arduino Software, Connect the D1 Mini to your computer through a data-capable cable and press the button below. Make sure you use the Chrome or Edge browsers on your computer for this to work.
Firmware for PCB Version 4.2+ including code for optional AirGradient SGP41 TVOC / NOx Module Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP! Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
Step Description
2 Once it is installed, go to File, Example, AirGradient and select the DIY_PRO_V4_2 code
Configuration
Configuration Number Temperature PM Unit Orientation
1 °C ug/m3 Top Left
2 °C US AQI Top Left
3 °F ug/m3 Top Left
4 °F US AQI Top Left
5 °C ug/m3 Bottom Right
6 °C US AQI Bottom Right
7 °F ug/m3 Bottom Right
8 °F US AQI Bottom Right
Dashboard Onboarding Wizard
