Error: This monitor already exists on another location
If you see this message:
Error. This monitor already exists on location xxx on place xxx. Please unlink this monitor first in the dashboard.
It means your AirGradient monitor is already registered in another dashboard (Place).
Why this happens
Each AirGradient monitor can only be linked to one dashboard (Place) at a time.
Before adding it to a new account or Place, it must first be removed from the previous one.
How to fix it
You need to unlink the monitor from the existing dashboard first.
Steps
  1. Open the AirGradient Dashboard
  2. Go to Hardware
  3. Find the monitor listed in the error message
  4. Click the Admin (gear) icon
  5. Select Edit Monitor
  6. Click Delete
After that, you can register the monitor again in your new dashboard or new location.
Important: Your old data
You do not need to delete the location associated with the monitor if you want to keep historical data.
If you're unsure about the difference between Places, Locations, and Hardware assignments, see this guide:
What are Places and Locations in the AirGradient Dashboard?
Deleting only the monitor removes the device assignment, while the location and past readings can remain.
If you no longer need the old location, you can delete it in Locations > Admin > Edit Location > Delete
Still cannot move the monitor?
If you no longer have access to the old dashboard, contact AirGradient support and share your monitor serial number.
