What are Places and Locations in the AirGradient Dashboard?
Understanding how Places and Locations work will help you organize your monitors correctly.
Places: Your main space
When you first create an account in the AirGradient Dashboard, you create a Place.
A Place represents a broader environment or project where your monitors are deployed.
For example, your home, an office building, a school campus or city-wide air quality project.
Think of a Place as a container that holds all your monitors.
Multiple Places
You can have multiple Places to manage different setups separately. You can switch between Place using the Place Selector drop-down:
For example, different households or separate research or deployment projects.
You can create multiple Places using the instructions here: Create a New Place and Move Locations Between Places in the AirGradient Dashboard
Locations: Where each monitor is installed
Inside a Place, each monitor is assigned a Location.
A Location describes the specific physical position of a monitor.
Examples:
  • Living room
  • Bedroom
  • Office meeting room
  • Rooftop
  • Street corner
This helps you understand where each data point is coming from.
How monitors are structured
Each monitor in your dashboard is made up of:
  • Hardware: the physical devices (Hardware in the sidebar menu)
  • Location: where the devices records their data (Locations in the sidebar menu)
Together, they form a complete monitor setup inside your Place.
When you connect a monitor using the onboarding flow, the Hardware entity is created and a Location is created and auto-assigned to that monitor.
The significance of this is that a single monitor can be linked to different Locations over time.
This is useful when you want to move a device to a new environment temporarily but keep datasets separate and clean.
Let’s say you move a monitor from your Living Room to your Bedroom.
Instead of using the same Location, you can:
  • Go to Locations → Admin → Go to location details → Edit Locations
  • Click Linked Monnitor
  • Select Remove the monitor from the current Location (this unlinks it)
  • Click Save
  • Create a new Location (Locations > Add New Location)
  • Click Linked Monitor
  • Select the same monitor to link it to the new Location
You can also move a locations across Places while preserving the historical data: Create a New Place and Move Locations Between Places in the AirGradient Dashboard
What happens to the data?
  • The old Location keeps its historical data
  • The new Location starts a fresh dataset
  • Only the Location currently linked to the monitor will show live data
