How to connect the Monitors to the AirGradient Dashboard
Connecting the monitor to the AirGradient Dashboard is a two-step process.
Connecting the monitor to the AirGradient Dashboard is a two-step process. You need to connect your monitor to the WiFi network and register it on the dashboard. To do so, the easiest way is to use our onboarding wizard:
IMPORTANT
In case you get an error message when scanning the "To WiFi" QR Code on the monitor, then connect them with the non-QR code method described in the onboarding wizard (login required) and also here.
