The AirGradient DIY Air Quality Sensor (Basic Version PCB Version 3.0)
(Basic Version)
(Basic Version)
Please note that these are the instruction for the DIY BASIC PCB Version 3.0 that mounts the S8 CO2 sensor differently. The version number is written on your PCB. If you have a different version please find your correct build instructions in this overview.
As part of the Open AirGradient movement, this instruction teaches you how to build a compact and powerful air quality monitor with AirGradient.
You will need to have good soldering skills. If you lack soldering skills, we also offer the DIY Pro kit as a pre-soldered version for a very easy assembly that can literally be built in 5-10 minutes. More Information about the pre-soldered kit.
If you want to build a monitor with a larger display, a better enclosure and more extensibility, check out the DIY Pro instructions.
Fully assembled kit. Please note PCB v3.0+ mounts the CO2 sensor in the opposite way.
Jeff featured our DIY Basic kit on his YouTube channel and created a very nice video on how to assemble the monitor.
Skills and Equipment required
SkillExplanation
Soldering skillsThe D1 Mini microprocessor and some of the components such as the OLED display need to have the pins soldered onto them. Soldering tutorial..
Soldering iron & SolderTo solder the component pins and cables.
BreadboardA breadboard is helpful to fix the components in place during soldering.
ComputerA Linux, Mac, or Windows computer with the Arduino IDE installed to flash the software onto the D1 Mini.
USB C Data CableTo connect the D1 Mini to the computer for flashing and later for electricity. Please make sure you have a USB C cable that not only charges but can also transfer data (for flashing).
ComponentApprox. Price
Wemos D1 MiniUSD 2 - 4
Wemos OLED displayUSD 2 - 3
Plantower PMS5003 PM SensorUSD 15 - 20
Senseair S8 CO2 SensorUSD 25 - 30
SHT30 or SHT31 Temperature and Humidity Sensor ModuleUSD 3 - 5
PCBSee below on how to make a PCB
EnclosureSee below on how to 3D print the enclosure
You can also purchase the kit from our Online Store. We ship world-wide.
In case you want to make your own PCBs you can download the Gerber files from PCB the Easyeda website or order PCBs from there directly. Make sure you download v3 of the PCB drawings.
Built without PCB
Built without PCB
Features
With temperature in Celcius Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
With temperature in Fahrenheit Your browser doesn't support this. Please use Chrome or Edge on Mac or PC. You are not allowed to use this on HTTP!
StepDescription
2Once it is installed, go to File, Example, AirGradient and select the DIY_BASIC code
5Once you have successfully uploaded the code you can continue building the hardware
OLED soldering
OLED soldering
Put the long female and male pins through the D1 Mini. Make sure that the female parts are on top of the D1 Mini (on the same side like the USB C plug) as shown in this picture and that the labels of the OLED pins and the D1 mini align:
D1 Mini soldering.
D1 Mini soldering.
D1 Mini Soldering Onto PCB
The next step is to solder the D1 Mini onto the PCB. Please make sure you solder it the correct way. The USB port needs to face outwards. You can also compare the pin labels on the PCB with the ones on the D1 Mini. You can either solder the D1 Mini directly onto the PCB or use the pin headers as a socket. If you solder it directly, please leave a small gap between the PCB and the D1 Mini to make sure the plug is accessible.
D1 Mini PCB soldering
Soldering The Temperature and Humidity Module
The kit might come either with the SHT3x module or the SHT40 module. The modules have a different design, so please follow the instructions below.
Instructions for SHT3x Module
If you have the SHT3x module, you need to first solder the small pins onto the module, you can again use a breadboard to fix it in place. You only need to solder the four pins. No need to do anything with the two pins on the top of the sensor.
For easier replacement of the sensor modules, solder a 4 pin female header onto the board and then put the SHT3x module onto the pin header as per picture below.
::hugo-doc-image-shortcode{src="sht3xbasic.jpg" width="350px"caption="SHT 3x Module Placement"} ::
Instructions for SHT40 Module
If you have the SHT40, you do not need to solder pins as the 90 degree pins are already soldered on it but you need to solder a 4 pin female header onto the board and then put the module on it. Please note that when you put the SHT40 module onto the pin headers it needs to face backwards as per the image below.
::hugo-doc-image-shortcode{src="sht40basic.jpg" width="350px"caption="SHT 40 Module Placement"} ::
Solder female pin headers onto the S8 PCB. Then put the S8 onto the pin headers.
Please make sure that the pins face as can be seen on this image. If you purchase the kit from us, these pins are already soldered on.
Please note that in previous versions of this PCB, the pins were soldered in the opposite way.
You can use ZIP ties to fix the S8 into place.
PMS JST Connector
PMS JST Connector
PMS Cable Wiring
PMS Cable Wiring
PMS Cable Connection without JST Connector
After you have soldered the cable or connector to the PCB, connect the PMS5003 with the other end of the cable. Then screw the PMS5003 onto the PCB or use a double sided tape to fix it in place.
Done & Enjoy
3D Enclosure And Mount
Download Enclosure STL Files
3D printable enclosure
AirGradient offers a sophisticated, powerful and responsive Air Quality Monitoring Solution for Schools. You can connect these DIY monitors to the AirGradient platform, and integrate with many existing brands or use our professional AirGradient ONE monitor.
