AirGradient Go: Settings
Open Settings
- Unlock the monitor with a short press of the On/Off/Unlock button.
- Press Menu/Select to open the main menu.
- Use Up or Down to select Settings.
- Press Menu/Select to open Settings.
- Use Up or Down to select a setting, then press Menu/Select.
Depending on the chosen operation mode settings can include:
| Setting | Options shown on the monitor | What it is used for |
| Setup Guide | Action | Opens the on-device getting started guide. Use this if you want to access the QR code to the quick start guide again. |
| Units | C, F | Changes the temperature unit shown on the monitor. Use C for Celsius or F for Fahrenheit. |
| PM Display | ug/m3, USAQI | Changes how particulate matter is shown on the home screen. Use ug/m3 or USAQI to show the US AQI value. |
| Measure Int. | 3s, 10s, 30s, 60s, 5m, 15m, 1h | Sets how often the monitor takes readings. Shorter intervals update more often and can use more battery. The default is 10 seconds. |
| GPS Mode | Always Off, On When Tracking, Always On | Controls when GPS is active. Always Off keeps GPS off and the monitor does not collect GPS coordinates, including while Tracking is active. Sensor readings will still be recorded. On When Tracking uses GPS while route tracking is active. Always On keeps GPS available even when you are not actively tracking, which can use more battery. |
| Mode | Stationary, Portable, Offline / Airplane Mode | Changes how the monitor connects and sends data. Use Portable when carrying the monitor with the app. Stationary when leaving it in one place with WiFi. Offline / Airplane Mode for local use without active radio data streaming. See AirGradient Go Operating Modes. |
| Auto Lock | Off, 10 Seconds, 30 Seconds, 60 Seconds | Sets whether the monitor locks itself after a period without button input. When locked, the front touch buttons do not navigate menus. Use On/Off/Unlock button to toggle Lock/Unlock |
| AQI LED | Off, Dim, Mid, Bright | Sets the brightness of the back AQI LED. |
| Touch LED | Off, Dim, Bright | Sets the brightness of the touch button LEDs on the front of the monitor. |
| Buzzer | Off, On | Turns monitor sounds off or on. |
| Play Melody | Chime, Tetris | Plays a short sound and light preview. This is a one-time action and does not change the buzzer setting. |
| CO2: Calibrate | Confirm: Yes or No | Starts the CO2 calibration action when confirmed. The CO2 sensor must be manually calibrated outdoors before first use. Follow AirGradient Go: CO2 Readings and Calibration for the complete procedure. |
| Data: Clear Data | Confirm: Yes or No | Clears stored data from the monitor when confirmed. |
| Hardware Test | Peripheral, GPS, Accel, FG Learning | Opens diagnostic tests for hardware checks. Use this when instructed by AirGradient support or during hardware verification. |
For basic button behavior, see AirGradient Go: Buttons and Navigation.
Questions or feedback?
