What parameters do AirGradient monitors measure?
This page explains what each parameter means, why it is measured that way, and how frequently data is recorded.
For a more detailed list refer to: https://github.com/airgradienthq/arduino/blob/master/docs/local-server.md
Time Resolution
  • Wi-Fi model: 1-minute intervals
  • Cellular model: 3-minute intervals
Particulate Matter (PM)
PM2.5 (µg/m³) – Raw (cf_atm)
Description: Raw, uncorrected mass concentration of airborne particles ≤ 2.5 µm.
Why µg/m³? Micrograms per cubic meter represents the total mass of inhalable particles in a given air volume. This is the global standard used in air quality regulations and guidelines.
PM2.5 (µg/m³) – Corrected
Description: PM2.5 value adjusted using the calibration formula selected in the dashboard.
Why corrected? Calibration formulas compensate for sensor characteristics and environmental factors to improve real-world accuracy.
PM1 (µg/m³)
Description: Mass concentration of particles ≤ 1 µm.
Why µg/m³? Provides a mass-based measure of very fine particles, which can penetrate deeply into the lungs.
PM10 (µg/m³)
Description: Mass concentration of particles ≤ 10 µm.
Why µg/m³? Indicates larger respirable particles such as dust.
Note: Optical sensors are optimized for PM2.5. PM10 values are less reliable. Very large particles (e.g., pollen >10 µm) are generally not detected.
PM 0.3 µm Particle Count (per dL)
Description: Number of particles ≥ 0.3 µm, measured as number concentration.
Why particle count? Particle count tracks the number of particles regardless of mass. Small particles may be high in number but low in weight, so count-based metrics can reveal events mass-based PM values may miss.
Other extended Particle Count measures available on request:
  • Particle count 0.5µm per dL
  • Particle count 1.0µm per dL
  • Particle count 2.5µm per dL
  • Particle count 5.0µm per dL
  • Particle count 10µm per dL
Carbon Dioxide (CO₂)
CO₂ (ppm) – Raw
Description: Measured carbon dioxide concentration.
Why ppm? Parts per million reflects volumetric gas concentration and is the standard unit for tracking indoor CO₂ buildup from human activity.
Temperature & Humidity
Temperature (°C) – Raw
Description: Ambient temperature near the sensor.
Why °C? Direct physical measurement affecting comfort and sensor performance.
Indoor monitors: Raw temperature closely reflects room conditions.
Outdoor monitors: Raw temperature may diverge from true ambient because the sensor sits inside the enclosure. Corrected values compensate for this.
Temperature (°C) – Corrected
Description: Temperature adjusted using a calibration formula.
Why corrected? Improves ambient accuracy, especially for outdoor units.
Humidity (%) – Raw
Description: Ambient relative humidity near the sensor.
Why % RH? Relative humidity expresses water vapor content relative to saturation. It influences comfort, condensation, and sensor behavior.
Outdoor monitors: Raw values may diverge due to enclosure effects; corrected values compensate for this.
Humidity (%) – Corrected
Description: Relative humidity adjusted using a calibration formula.
Why corrected? Improves ambient accuracy for outdoor deployments.
Heat Index (°C)
Description: Calculated apparent temperature combining corrected temperature and humidity. Why calculated? Reflects how hot it actually feels when humidity is considered.
VOC (Volatile Organic Compounds)
TVOC (ppb)
Description: Total VOC concentration converted to ppb using Sensirion’s formula.
Why ppb? Reported in parts per billion for familiarity, but this is a relative estimate derived from the VOC index — not an absolute concentration.
TVOC Index (1–500)
Description: Scaled index representing total VOC activity.
  • 100 = baseline
  • greater than 100 = more VOCs than recent 24-hour baseline
  • <100 = fewer VOCs than baseline
Why an index? MOx sensors respond broadly to many VOCs. Exact ppb estimates are unreliable, so a unitless index is better for detecting trends.
Adaptive behavior:
  • In clean air → becomes more sensitive to small changes
  • In polluted air → reduces sensitivity to avoid saturation
TVOC Raw log(R)
Description: Logarithmic raw resistance output from the MOx sensor.
Why log(R)? MOx sensors measure resistance changes of a heated metal oxide surface.
  • Reducing gases (VOCs) → decrease resistance
  • Oxidizing gases → increase resistance
  • Output is broadband and non-specific.
NOx (Nitrogen Oxides)
NOx Index (1–500)
Description: Scaled index representing oxidizing gas activity.
  • 1 = baseline
  • greater than 1 = increased oxidizing gases
Why an index? Similar to VOC, MOx sensors detect general oxidizing gases rather than specific compounds.
Note: The NOx index does not use adaptive gain like the VOC Index
NOx Raw log(R)
Description: Logarithmic raw resistance from the NOx MOx sensor.
Why log(R)? Resistance increases in presence of oxidizing gases such as NOx. Output reflects general oxidizing gas presence rather than specific concentrations.
Related articles
