How to Remove a Monitor from the AirGradient Dashboard
Remove a Monitor
Steps
  1. Open the AirGradient Dashboard
  2. Go to Hardware in the sidebar menu
  3. Find the monitor you want to remove
  4. Click the Admin (gear) icon
  5. Click Edit Monitor under Monitor Information
  6. Click Delete
This removes the monitor from your dashboard and unlinks it from that location.
Remove a Location
Deleting the monitor hardware entity removes only the monitor association. Deleting a Location also removes the data linked to that Location. Do not delete the original Location if you need to preserve its historical data. That data remains in the original dashboard; it does not move to the new dashboard. This method does not preserve data continuity across Locations. If you need to preserve the historical data and transfer it with the monitor, contact support before removing the monitor.
If, however, you no longer need the linked location (What are locations?), you can delete it as well:
Steps
  2. Go to the Locations in the sidebar menu
  3. Open the Admin settings for the location you want to remove using Admin (gear) icon
  4. Click Edit Location
  5. Click Delete
Note: Deleting a monitor (the hardware entity) removes only the device, deleting a location also removes the data linked to that monitor.
Need to Re-register the Device?
After the monitor has been removed, it can be registered in another dashboard or the same dashboard Place. For the complete move workflow, see How to Move a Monitor to Another AirGradient Dashboard.
