Troubleshooting WiFi Connectivity Issues
Before continuing, make sure you have followed the WiFi setup steps exactly as shown in the written instructions or video guides:
Connecting Your AirGradient ONE to WiFi
Connecting Your AirGradient Open Air to WiFi
If the setup steps or videos were skipped, incomplete, or done in a different order, WiFi connection issues are very likely.
Only continue with the troubleshooting steps below after confirming the setup guide was followed correctly.
If the WiFi network you want to connect your AirGradient ONE to doesn’t appear in the WiFi configuration settings, or the device fails to connect, it’s almost always due to one of the limitations below:
5 GHz WiFi is not supported
AirGradient devices only support 2.4 GHz WiFi.
5 GHz-only networks will not appear in the WiFi configuration menu.
A single (unified) SSID (WiFi name) that combines 2.4 GHz + 5 GHz can cause connection failures. This behavior depends on the router.
Some routers with a single (unified) SSID for both 2.4 GHz and 5 GHz work fine. Others don’t, and may prevent the device from seeing the network or completing setup. If this happens, the best split the WiFi into two separate SSIDs:
one for 2.4 GHz
one for 5 GHz
Then, connect the device to the 2.4 GHz SSID
Important Note
- The steps to split WiFi radios vary by router manufacturer. In most cases, you need to disable “band steering”.
Quickly rule out device vs. network issues (Mobile Hotspot Test)
One of the fastest ways to identify whether the issue is with your AirGradient device or your WiFi network is to try connecting the device to a mobile hotspot.
How to test
Enable a mobile hotspot on your phone (make sure it uses 2.4 GHz, if your phone allows choosing). If using an iPhone and the hotspot does not appear, turn on Maximize Compatibility in Settings → Personal Hotspot.
Use a simple hotspot name (SSID) and password (avoid special characters)
Go through the normal WiFi setup steps and connect your AirGradient device to the hotspot
What this tells you
If the device connects successfully to the hotspot and shows online in the Dashboard:
- The device is working correctly
- The issue is with your WiFi network (router settings, firewall, band steering, etc.)
If the device fails to connect to the hotspot as well:
- There may be a device-related issue
- Proceed with firmware reflash or contact support.
Enterprise / managed networks are not supported
AirGradient devices do not support enterprise or managed WiFi networks, including WPA2-Enterprise or WPA3-Enterprise, certificate-based authentication, captive portals (login pages), or networks that require a proxy.
These types of networks are commonly used in schools, universities, corporate offices, government buildings, hotels, and public WiFi.
If you are on such a network, contact your IT administrator and either connect the device to a standard 2.4 GHz personal WiFi network or deploy it on a separate IoT / sensor-only WiFi network.
Firewall and outbound traffic restrictions
Some networks block outbound traffic by default. If outbound access is restricted, the WiFi setup may fail during setup or the device will appear “offline” on the Dashboard after setup.
AirGradient devices require outbound HTTPS access only to:
167.233.8.149 , 91.98.9.143 , and 46.225.42.92
Test Network Connectivity (Ping Test)
If the device connects to WiFi but shows offline in the Dashboard and the purple LED on the device is on, the network may be blocking outbound traffic.
AirGradient devices require outbound HTTPS access to:
You can test basic network reachability from the same network using a computer. Run in a Terminal (iOS) or Command Prompt (Windows):
ping hw-ec.airgradient.com
and ping hw.airgradient.com
Expected Result
You should see replies similar to:
64 bytes from 91.98.9.143: icmp_seq=0 ttl=49 time=68.751 ms
If you get a timeout response:
The network is likely blocking outbound traffic
Ask IT to allow outbound HTTPS traffic to
167.233.8.149,91.98.9.143and46.225.42.92
Hidden SSIDs
Hidden networks usually won’t show up in the list. Enter the SSID and password manually in this case.
Router security settings
Some routers block new or IoT devices by default.
Check for:
MAC filtering: use the device serial number to set up an exception.The monitor serial number (SN) is the device’s MAC address, formatted without colons. Example: Serial number shown on device / dashboard: abcdefghijkl ; corresponding MAC address: ab:cd:ef:gh:ij:kl
“Allow only approved devices” settings
Still not working?
Power-cycle the router
Reset the device’s WiFi configuration and try again
Move the device closer to the router during setup
Power cycle the monitor itself.
Reflash the device firmware.
Contact us via the Support Form or email support@airgradient.com
