AirGradient Go: Technical Specifications
The AirGradient Go measures air quality and environmental parameters, and it also records other monitor status data.
Air quality and environmental parameters:
  • Particulate matter
  • CO2
  • TVOC index and NOx index
  • Temperature and humidity
  • Barometric pressure and altitude
Other parameters:
  • GPS latitude, longitude, altitude, fix type, satellite count, and timestamp
  • Battery percentage, battery voltage, charging voltage, and charging state
If a sensor is warming up or a parameter is unavailable, the monitor will show it as blank with a — symbol in the display.
Technical specifications
Specification Description
Model P-1PSG
Dimensions and weight 103 x 68 x 31 mm, 137 g
Particulate matter sensor Sensirion SPS30, light scattering
CO2 sensor SenseAir S12
TVOC/NOx sensor Sensirion SGP41
Temperature, humidity, and pressure Sensirion SHT40 and Infineon DPS368
Connectivity Bluetooth LE, WiFi 2.4 GHz and 5 GHz
GPS Allystar TAU1113
Accelerometer STMicroelectronics LIS2DH12
On-device storage 64 MB
Display 2.1 inch e-ink
Battery 2000 mAh Li-Po
Enclosure ASA plastic bottom, polycarbonate top, UV resistant and weather resistant
Included accessories Carry bag, USB-C cable, and hand strap
Open source Open Source Hardware under CC-BY-SA. Firmware source code is available on GitHub.
Related articles
Questions or feedback?
