What AirGradient Go Measures
Measurement summary
| Parameter | Hardware |
| PM1.0, PM2.5, PM10 mass concentration | Sensirion SPS30 |
| CO2 | SenseAir S12 |
| TVOC index, NOx index, and raw SGP41 values | Sensirion SGP41 |
| Temperature and relative humidity | Sensirion SHT40 |
| Barometric pressure and pressure-based altitude estimate | Infineon DPS368 |
| GPS location data | Allystar TAU1113 |
| Movement/orientation | STMicroelectronics LIS2DH12 |
More details: AirGradient Go: Technical Specifications.
How readings appear
You can view AirGradient Go data in three ways:
On the monitor: The display shows readings when you use the Go on its own. No phone or dashboard connection is required.
In the AirGradient app: In Portable mode, the app connects to the Go over Bluetooth and shows current readings. Pair the monitor with the app using Pair AirGradient Go With the AirGradient App.
In the AirGradient Dashboard: There are two dashboard paths:
In Portable mode, the Go sends readings over Bluetooth to the phone. The app can then upload those readings to the dashboard when Stream data to server is enabled in Configure My Monitor. The app continues to show current readings, while the dashboard stores the uploaded data.
In Stationary mode, the Go connects to WiFi and sends readings directly to the dashboard. This is the dashboard-only path; the app is not used as the data relay. See Connect AirGradient Go to WiFi.
If a sensor is warming up, or a reading is invalid or unavailable, it may be shown as a dash or blank.
To understand Dashboard values, units, colors, and graphs, see AirGradient Dashboard: Measurements and Interpretation.
PM1.0, PM2.5, and PM10
PM means particulate matter: small airborne particles such as smoke, dust, combustion particles, and other aerosols.
AirGradient Go reports three particle-size groups:
| Reading | Meaning |
| PM1.0 | Particles with an approximate diameter of 1.0 micrometer or smaller |
| PM2.5 | Fine particles with an approximate diameter of 2.5 micrometers or smaller |
| PM10 | Particles with an approximate diameter of 10 micrometers or smaller |
The monitor uses a Sensirion SPS30 particulate matter sensor. It estimates particle concentration using light scattering: air passes through the sensor, particles scatter light, and the sensor converts that signal into particulate readings.
Other AirGradient monitor models use Plantower PM sensors, so differences of up to 5 µg/m³ are expected when comparing individual readings with AirGradient Go. For a useful comparison, place the monitors together and compare readings over the same period rather than comparing individual measurements.
The main display focuses on PM2.5 because it is the most accurate PM metric commonly used for health guidance and AQI calculations. PM readings are reported as mass concentration in micrograms per cubic meter (ug/m3) or as USAQI when that display mode is selected.
PM readings can change quickly when the monitor is near smoke, cooking, dust, traffic, or other local particle sources. Avoid blocking the sensor inlet or placing the monitor deep inside a bag when you want representative readings.
CO2
CO2 means carbon dioxide. AirGradient Go reports CO2 in parts per million (ppm).
CO2 is useful for understanding ventilation in occupied spaces. It usually rises when people breathe in an enclosed area and ventilation is limited. Outdoor CO2 is typically much lower than crowded or poorly ventilated indoor spaces.
AirGradient Go measures CO2 with a SenseAir S12 CO2 sensor.
The sensor must be manually calibrated outdoors before first use; otherwise, its readings may be inaccurate. Follow AirGradient Go: CO2 Readings and Calibration before assessing or comparing the CO2 readings.
TVOC index
TVOC means total volatile organic compounds. These are gases that can come from sources such as solvents, cleaning products, paints, adhesives, smoke, personal-care products, cooking, and many indoor materials.
AirGradient Go uses a Sensirion SGP41 gas sensor for TVOC-related readings.
The normal TVOC value is an index, not a direct concentration in ppb or mg/m3. The index is designed to show changes in VOC conditions over time. A higher index means the sensor is detecting a stronger VOC-related signal compared with its recent baseline.
Use TVOC index trends rather than treating a single number as an exact chemical concentration. The sensor does not identify which VOC is present.
Learn more about this sensor here: Explaining VOCs, TVOC and the VOC Index
NOx index
NOx means nitrogen oxides. NOx-related signals can be associated with combustion sources such as traffic, gas appliances, burning, and other outdoor or indoor combustion events.
AirGradient Go uses the same Sensirion SGP41 gas sensor for NOx-related readings.
The normal NOx value is also an index, not a direct concentration in ppb. It is useful for seeing changes and trends, but it does not identify a specific gas or provide a regulatory-grade concentration.
More detail: Why the SGP41 Can't Measure Ambient NOx
TVOC and NOx in Offline mode
In Portable and Stationary modes, AirGradient Go can calculate TVOC and NOx index values from the SGP41.
In Offline / Airplane Mode, the monitor shows raw SGP41 values instead of TVOC and NOx index values because the continuous gas-index calculation is not maintained across deep-sleep cycles.
If you need TVOC and NOx index values, use Portable or Stationary mode where possible.
Temperature and humidity
AirGradient Go measures temperature and relative humidity with a Sensirion SHT40 sensor.
The temperature sensor is affected by heat generated by the battery and other internal components. Relative humidity depends on temperature, so the warmer conditions inside the monitor can also make the humidity reading appear lower. Temperature and humidity compensation is planned for a future firmware update.
Temperature is shown in Celsius or Fahrenheit depending on the monitor setting. Humidity is shown as relative humidity in percent.
These readings describe the air near the monitor. They can be affected by:
- heat generated by the battery and other internal components
- direct sun
- body heat from carrying the monitor
- warm electronics nearby
- rain, condensation, or very humid air around the enclosure
- airflow around the monitor
Internal heat can make the reported temperature higher than the surrounding air. Because relative humidity depends on temperature, this can also make the reported humidity lower.
We are working to address this with temperature and humidity compensation in a future firmware update.
Barometric pressure and altitude estimate
AirGradient Go measures barometric pressure with an Infineon DPS368 pressure sensor.
Pressure is reported in hectopascals (hPa). The monitor can also derive a pressure-based altitude estimate.
AirGradient Go currently estimates altitude from atmospheric pressure, not GPS. Sea-level pressure changes with weather conditions, so the calculated altitude can be higher or lower than the actual altitude and may sometimes be negative.
An inaccurate altitude estimate does not mean that the monitor is defective. It is a limitation of calculating altitude directly from the current pressure reading without local sea-level pressure data.
We are investigating an improved calculation that uses local sea-level pressure information. This may require an internet connection or GPS-based location data.
GPS location and time
AirGradient Go uses an Allystar TAU1113 GPS module.
When GPS has a fix, the monitor can use or store:
- latitude
- longitude
- GPS altitude
- fix type
- satellite count
- GPS timestamp
GPS data is mainly used for route tracking and location-aware records. A route can start before GPS has a fix, but route points include location data only after a fix is available.
The GPS fix icon appears in the top status bar when a usable GPS position is available. It looks like a small upward caret or open triangle (/\). If the icon is not shown, move outdoors with a clearer view of the sky and wait for GPS.
For more detail, see AirGradient Go GPS and Route Tracking and AirGradient Go: GPS Fix Troubleshooting.
Motion and orientation
AirGradient Go includes an STMicroelectronics LIS2DH12 accelerometer.
The accelerometer is used for monitor features and diagnostics that need movement or orientation input. It is not an air-quality measurement, and it is not a replacement for GPS route position.
Battery and charging status
AirGradient Go includes a 2000 mAh Li-Po battery and power-management hardware.
Power-related values can include:
- battery percentage
- battery voltage
- charging voltage
- charging state
- whether the monitor is plugged in
Battery readings help explain runtime and charging behavior. They are also stored with route data so you can understand the monitor state during a session.
For display units and measurement interval settings, see AirGradient Go: Settings.
Questions or feedback?
