AirGradient Go: Display Icons and Status Indicators
Battery icons
The battery icon shows the monitor's approximate battery level. The percentage ranges are grouped as follows:
Icon Battery level What it means
0-10% The battery is very low. Connect the monitor to USB-C power.
10-30% The battery is low.
30-50% The battery is between roughly one-third and one-half full.
50-70% The battery is more than half full.
70-95% The battery is high but not in the highest range.
95-100% The battery is near full or full.
Charging USB power is connected and the battery is charging.
Plugged in USB power is connected and the battery is full or nearly full.
At the boundary between two ranges, the monitor uses the lower range. For example, exactly 30% uses the 10-30% icon, and exactly 95% uses the 70-95% icon.
For charging and battery information, see Charge and Power Off AirGradient Go and AirGradient Go: Battery Life and Battery Care.
Connection and status icons
Icon Status What it means
Bluetooth connected The monitor is connected over Bluetooth.
Bluetooth not connected Bluetooth is available for the current mode (portable), but the monitor is not connected.
WiFi connected The monitor is connected to WiFi.
WiFi not connected Stationary mode is enabled, but the monitor is not connected to a WiFi network.
GPS fix The monitor has a usable GPS position.
Lock and unlock status
When the monitor is locked, the front Up, Down, and Menu/Select buttons do not navigate menus.
To unlock the monitor:
  1. Press the On/Off/Unlock button briefly.
  2. Use the front buttons after the unlocked status appears.
To lock the monitor again, press the On/Off/Unlock button briefly.
For button and menu details, see AirGradient Go: Buttons and Navigation.
Locked The front Up, Down, and Menu/Select buttons are locked.
Unlocked The front touch buttons can be used.
Tracking status
When route tracking is active, the display shows the small circular tracking dot. The tracking dot means that a tracking session is active. It does not indicate whether GPS coordinates are being collected. GPS data depends on the selected GPS Mode and whether a GPS fix is available.
For route details and steps to start or stop tracking, see AirGradient Go: Route Tracking and GPS.
Tracking active Route tracking is active. The monitor uses a small circular dot for this status.
Icons by operating mode
Some connection icons depend on the operating mode:
Mode Typical connection status
Portable Bluetooth connection to the app
Stationary WiFi connection
Offline / Airplane Mode No active Bluetooth or WiFi data stream
For more detail, see AirGradient Go: Operating Modes.
GPS fix icon
The GPS fix icon appears when the monitor has a usable GPS position. It looks like a small upward caret or open triangle (/\) in the top status bar.
If the icon is not shown, the monitor does not currently have a GPS fix. The monitor does not show a separate no-fix icon. GPS reception is affected by the monitor's location, buildings, tree cover, vehicles, and the selected GPS mode.
For GPS guidance, see AirGradient Go: GPS Troubleshooting.
